My AC is blowing cold only on the driver side. The two vents on the passenger side are blowing hot. I had the system checked and recharged less than 1 month ago. Everything was fine. No leaks visible from dye injected. The system just started blowing hot on the right side all of a sudden. I've had the system checked by two independent certified mechanics/shops and each time the charge only lasts about a month or so. Yet no leaks. Am I looking at an expensive repair, such as an evaporator?
May 4, 2010 at 5:26 PM
