2004 BMW X3 P0599 code
80,000 MILES • 6 CYL • AWD • AUTOMATIC
ETHELBERT
im due w/ smog check.can't PASS x2 after even changing the coolant thermostat.we already went to 3 service centers.seemed like this P0599 manufacturer are a lot of things.im so confused already.first, it says thermostat control circuit high.then cruise control sensor,then 4x4,now the airbag light's on.
we don't know anymore.dealer asks$3000k for fixing 2 problem only.and i checked the sensors they're all @$29-$39.99 range.why charge costumers in $$$$?
pls.help what seemed to be the real P0599 trouble?how do we fix it?
Jul 25, 2010 at 7:18 AM
DOCHAGERTY
  • 9,606 POSTS
First, we need to have the car scanned with the proprietary BMW software to extract the reason the fault exists. The generic scan tools are not able to discern what the problem is and the P0xxx codes are manufacturers codes that do not correlate to what BMW says. Let me get clear about one other thing, the fault returns after you clear it with the generic tool, correct?
Jul 25, 2010 at 8:02 PM
