2000 Other BMW Models
2000 BMW
DUCKMAN
Electrical problem
2000 Other BMW Models 6 cyl Two Wheel Drive Manual
I have a 2000 BMW M Roadster. The gear shift knob has been loose due to a broken plastic clip that holds the knob to the shifter. Recently I tapped on the loose shifter and the interior instrument lights and the lighted knob itself went out. I checked the fuses in the fuse box in gthe engine compartment and they were fine. Is there another hidden fuse somewhere? If I accidently broke a wire or the bulb in the shift knob, are the instruments wired in series and therefore, all the instruments blew out? Any other ideas, suggestions?
Aug 9, 2008 at 11:26 AM
DOCHAGERTY
  • 9,606 POSTS
The knob will require replacement as the bulb is part of the knob.
Aug 9, 2008 at 5:38 PM
SURECOOL73
Hey,i too think that by replacing it the problem is solved.one of my friend had the same problem and now after changing its working perfect.
Apr 23, 2009 at 5:32 PM
DOCHAGERTY
  • 9,606 POSTS
Always good to have backup.................................
Apr 24, 2009 at 1:47 AM
