1992 Other BMW Models TIMING
1992 BMW
GEORGEJGLOVER
Engine Mechanical problem
1992 Other BMW Models 6 cyl Two Wheel Drive Manual
ive got a 1992 5 series 2.0l its a m50 24 vavle DOHC engine and im having trouble timing up. on the 2 smaller spockets that join the 2 cam shafts together there is 2 arrows on each one and on the bigger sprocket that joins the cam shaft to the drive shaft also has arrows on it can you just tell me where the arrows should be when the engine is at TDC on its compression stroke ?
Apr 23, 2008 at 10:58 PM
DOCHAGERTY
  • 9,606 POSTS
They should point straight up away from the crankshaft
Apr 24, 2008 at 2:21 AM
DOCHAGERTY
  • 9,606 POSTS
where is the toilet?
Dec 20, 2008 at 2:58 PM
