1988 Other BMW Models Transmission shifts only at high rpms
1988 BMW
164,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATTHEW69
My transmission just started having problems shifting. Sometimes when I start out it works great, but other times I have to run it up to high rpms, 4000+, to get it to shift from 1st to 2nd gear. I check the tranny fluid it is fine. Could this be a differential problem? Boy, trying to restore this old 88 735il is a pain sometimes.
Mar 16, 2008 at 8:16 AM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
This seems like an internal transmission issue, perhaps a broken spring on a piston in the shift body of the transmission would be my guess. I would start with inspecting the shift body of the transmission. Repost if more help is needed.
Mar 16, 2008 at 10:59 AM
