2005 BMW M3
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
JLDALLOVER
Car won't start and the OBD2 has P0123 code...
Feb 8, 2009 at 2:15 AM
DOCHAGERTY
  • 9,606 POSTS
Is the M3 a manual or SMG? An `05 BMW with less than 30k miles is still covered under the factory warranty, did you want to let BMW fix this issue for you? What does happen when you try to start it? The P0123 code is for a throttle position sensor plausibility and shouldn't keep the car from starting.
Feb 8, 2009 at 2:30 AM
