2003 BMW M3 Manual 65000 miles
I have a 2004 BMW M3 and recently installed a bluetooth (Parrot), XM radio and Ipod connector. The XM radio, Ipod connector work fine. The Parrot worked for the first two days and then just stopped - am unable to connect with my phone - but you can still here the menu options through the car speakers so I assuming that it is still connected fine. My problem is that the radio. It just shuts off after 20 minutes and you have to turn it back on. The other problem is that when you turn the car off the radio still stays on. I have not tested to see if the radio turns off automatically in 20 minutes when the car is turned off like it does when you are driving. Any ideas as to what the problem can be? Is there an automatic timer option on the radio that I just need to find and disconnect?[img:fa53abc7a1]http://www.2carpros.com/forum/automotive_pictures/210748_6958_1.jpg[/img:fa53abc7a1]
Jul 7, 2008 at 5:58 AM
