2003 BMW M3 das lights
133,421 MILES • 6 CYL • 2WD • MANUAL
O'KASI
I replaced a transversal acceleration sensor today on a BMW M3 Convertible 03 plate, the sensor was replaced because the handbrake, tracks ion control, tyre pressure lights where showing, diagnosis was carried out the result was to replace the above sensor.
After the sensor was replaced the lights were still showing, an attempt was made to reset the lights but it did not work, each time the diagnosing equipment was used to reset the lights it keep coming up to replace the same sensor: What can be done? how can I reset the lights? Can I do it myself? Is are a procedure for resetting the lights? and where can I have it reset?. Is there a mobile service for this type of problem.
Sep 1, 2010 at 8:28 AM
DOCHAGERTY
  • 9,606 POSTS
This could be a coding error, have you got BMW specific scanning tools?
Sep 1, 2010 at 12:14 PM
