1995 BMW M3 Window operation
150,000 MILES • 6 CYL • 2WD • MANUAL
TJ742002
My window occasionally doesn't want to raise straight. I've taken a part, realigned, adjusted. Works great for week and then does it again. New motor? Something bent? Movable parts worn?
Thanks.
Mar 6, 2008 at 12:01 AM
DOCHAGERTY
  • 9,606 POSTS
The white plastic track runners should be replaced and the back track for the felt channel should be inspected for damage. Lube the felt with dry silicone. Be sure to do this where it's warm as the plastic can be brittle when cold.
Mar 7, 2008 at 1:56 AM
