BMW IGNITION REFUSED TO TURN AFTER ONE 18 PASSENGER URVAN-BUS RAMMED INTO IT.
20,024 MILES
ONALO
  • 32 POSTS
My 1990 BMW 525 INTERFACE WITH TIMING BELT ignition key could not turn to crank and start my engine after one loaded 18 passenger URVAN bus left the express road and rammed in to it where it was packed. The rear right passenger camber was badly affected and had to be changed completely after removing the tyre While the two rear passenger doors got dented and ceased the ignition key from turning. So please what do I need to do in order to get it back to normal position again? Thanks for being there always.
Oct 21, 2013 at 5:15 AM
DOCHAGERTY
  • 9,606 POSTS
Replacement of the steering lock is going to require removal of the steering column. It takes special tools and skills, are you prepared?
Oct 27, 2013 at 1:51 PM
ONALO
  • 32 POSTS
Yes my mentor; Am very much prepared. Thanks a Million. ....!
Oct 27, 2013 at 10:17 PM
ONALO
  • 32 POSTS
Good morning Dr.Pls.there is this sign with a knob S -E -M besides my BMW's gearbox console.S is first, E is at the centre while M ends it. I want to know what it does when driving.NB.I've solved the previous problem without replacing anything. Thanks once again. DUNCAN.
Nov 13, 2013 at 1:38 PM
DOCHAGERTY
  • 9,606 POSTS
That switch is for the transmission
Nov 15, 2013 at 11:42 PM
