fault code 2CFB and 2D09
134,555 MILES • 3.5L • 6 CYL • RWD • AUTOMATIC
MB-POWER
  • 80 POSTS
Rpm's are going up and down all the time, engine power reduced! after scanned we found following codes : (2CFB) and (2D09).
Throttle body has been replaced with used one.
codes cleared also .
but after restart engine again , same codes came back!
Any help please.
Thanks
Aug 1, 2017 at 10:44 PM
STEVE W.
  • 15,411 POSTS
Check the wiring right at the TB, they are known for having loose pin fitment.
Next would be to do a full re-learn and reset of the throttle adaption. There are a few videos out there telling you how to do that using the throttle pedal. Unless you have access to a factory scan tool, those can do all of the resets as well as update the programming.
Aug 2, 2017 at 12:10 AM
MB-POWER
  • 80 POSTS
One of my friends advice me to replace the DME .
are you agree with him?
Thanks
Aug 2, 2017 at 12:42 AM
STEVE W.
  • 15,411 POSTS
I would start with the reset procedures. If they do not help then you may need to replace the DME, but then you still have to do the programming with a new one. Many times cleaning the connections and doing the reset will take care of those codes.
Aug 2, 2017 at 1:15 AM
MB-POWER
  • 80 POSTS
Okay I will do the reset first, but I would like to ask, is it important of voltage of battery to be more than 12.50V?
The battery voltage now is 9.02V.
Thanks
Aug 2, 2017 at 1:24 AM
STEVE W.
  • 15,411 POSTS
Yes, the battery needs to be at full charge. Low voltage can set codes as well.
Aug 2, 2017 at 2:30 AM
