2003 BMW E46 Car Losing Water
2003 BMW E46
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIHAQA
The car loses water when in motion eg if travelling at 70km/h the radiator alert will come on after a distance of about 8kms. Pressure testing was done and no problem detected. radiator was flushed but problem still persisting. Splatters are evident on the inside of the fan closest to the radiator. When radiator alert came on, temperature gauge was just below the half-way mark, as always. Water not mixing with oil.
What could be the problem? Please help.
Jan 12, 2009 at 10:56 PM
DOCHAGERTY
  • 9,606 POSTS
Replace the pressure cap.
Jan 28, 2009 at 11:44 PM
SUREMAN73
Sounds like the lower hose wasn't changed, I'm surprised you can't follow the leak.
Check again later, maybe when you were refilling it you let alot of air in the system and after driving it finally settled.
Apr 26, 2009 at 2:12 PM
