Do I have to program my car (XI model) after install a new battery? Or is it necessary?
Aug 5, 2018 at 6:56 AM
✓Experienced Mechanic
No, it should be fine is the car having issues since the change? I have seen voltage spikes play havoc on some cars when changing the battery.
Please get back to us.
Cheers, Ken
Aug 6, 2018 at 8:16 AM
JCCXCCJ23
MEMBER
No. It has not had an issue yet but I am waiting for the 120 amp 12 volt alternator to be delivered. And I do believe the final stage resistor or alternator was having a parasitic draw on the battery.. If that makes sense for common issues for BMW.
Aug 6, 2018 at 12:39 PM
Yep, alternator can go bad draining the battery. Here is a guide to show you what you are in for when changing the alternator out and diagrams to help you see how on your car below:
