1995 Other BMW Models 1995 840 csi
MONELLO1
Electrical problem
1995 Other BMW Models V8 Two Wheel Drive 60,345 miles
Hi i have a 840 bmw and I cant get the driver side turn signals to work nothing turns on, [img:0a6a4c4840]http://www.2carpros.com/forum/automotive_pictures/173116_harrelay_1.jpg[/img:0a6a4c4840]
[img:0a6a4c4840]http://www.2carpros.com/forum/automotive_pictures/173116_harrelay_2.jpg[/img:0a6a4c4840]the other side works fine and all the other lights work fine, brakes high beams and so on I bought the car this way so I dont know what to do I am also missing the steering relay that goes in the K199 Servonic slot under the engine and the dealer cant tell me wich relay I need to purchase to put in this slot. can you please help
thanks
John
Mar 27, 2008 at 4:33 PM
DOCHAGERTY
  • 9,606 POSTS
If the turn signals do not work, then the turn signal switch or the lamp control module are suspect. The only part# I can find is 32-43-1-165-157 for the servotronic control module, I will try to confirm this at work tomorrow and will repost if the part# is different.
Mar 27, 2008 at 6:10 PM
