1995 BMW 840 idles rough when started very cold, idles grea
84,300 MILES • V8 • 2WD • AUTOMATIC
BILL ALLEN
Just bought car. Ran grat until temps in AM got down to 30's. When started @this temp idles roughly down to 300 to 400 RPM from normal 600+ until warms up to mid range on tmep gauge. Then idles smoothly@600 RPM. Runs well above idle speed even when cold. Check engine light comes on after idles rough for a few seconds or so and then goes out when engine is run some more until warmed up. Oil change shows normal oil and antifreeze is normal also. No increase in either volume.
Nov 22, 2008 at 12:49 PM
DOCHAGERTY
  • 9,606 POSTS
The possibility of your recent purchase having some cold starting issues might be related to some factory recalls. Could you repost with the last 7 characters of the VIN so I can check history, thanks mate!
Nov 23, 2008 at 5:02 AM
DOCHAGERTY
  • 9,606 POSTS
CC89510 VIN shows a possible need for reprogramming, the DCS site is compromised at this time and i will try again on Friday the 5th.
Dec 4, 2008 at 4:49 PM
