1992 BMW 750Li key switch
JOSEBMW750IL
Interior problem
1992 BMW 750Li V12 Two Wheel Drive Automatic
how do i remove the key switch to a BMW750iL because it doesn't have any screws
Sep 15, 2010 at 6:26 AM
DR LOOT
  • 2,311 POSTS
IGNITION SWITCH Removal & Installation Disconnect negative battery cable. Remove lower left dashboard trim. Remove screws and steering column lower trim. Press in retaining hooks on both sides of switch, and pull out ignition switch. To install, reverse removal procedure. Check ignition switch-to-steering wheel lock position.
Sep 26, 2010 at 4:01 AM
