Under the hood, look for the oil cap which will usually be black with yellow drawing of an engine or letters O- I - L on it. It should also have labeled the recommended weight of oil for your vehicle.
Please not that this is NOT the dip stick hole. This is a seperate, much larger hole with a screw on cap.
Hope this helps..
Thanks for using 2carpros.com!
Jan 10, 2009 at 8:37 AM
DOCHAGERTY
✓Experienced Mechanic
The oil fill is located at the front of the right valve cover.
Jan 10, 2009 at 11:53 AM
