2004 BMW 745 COOLANT
2004 BMW 745
KELEESH
2004 BMW 745
WHY IS MY CAR LEAKING
Jun 24, 2009 at 11:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What is it leaking? (oil, coolant, fluild..) Where is it leaking at? (under hood, exhaust etc..). When does it leak and how badly? (only while driving, when idling, etc..)
Jun 24, 2009 at 12:08 PM
KELEESH
it looks like its leaking behind the water pump out of a small hole on the block {coolant}
Jun 24, 2009 at 12:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Are you sure it isn't the waterpump itself leaking? It can leak causing it to appear to be leaking from the block..they will leak when they begin to fail
Jun 24, 2009 at 2:16 PM
KELEESH
COULD BE! I JUST WANTA MAKE SURE I CAN SEE THE HOLE IN THE BLOCK I DONT KNOW IF ITS SPOSE TO BE PLUGGED OR NOT!
Jun 24, 2009 at 2:53 PM
DOCHAGERTY
  • 9,606 POSTS
The work is extensive. It is an O-ring failure. 16 hours labor. Will you do it yourself?
Jun 24, 2009 at 3:44 PM
KELEESH
THANK YOU WHERE IS THE O RING
Jun 24, 2009 at 7:10 PM
DOCHAGERTY
  • 9,606 POSTS
It is behind the front timing case.
Jun 26, 2009 at 1:35 AM
