2002 BMW 745 window regulator
96,000 MILES • V8 • 2WD • AUTOMATIC
SPDFAS
Passenger side regulator is slipping. How you you remove the door panel ? I have removed all visiable srews (4) Two under the arm pad, one from inside door pull handle and one from the left inside door jam.
Jul 23, 2008 at 1:54 AM
DOCHAGERTY
  • 9,606 POSTS
Using a "bone tool" or a silicone wedge tool, get between the door panel and the door and "pop" it loose.
Jul 23, 2008 at 1:37 PM
