2002 BMW 745 Transmission fail safe
34,000 MILES • V8 • 2WD • AUTOMATIC
MFSUTN
My car was down shifting into 1st hard when the car was stopped rapidly from a higher speed. Now the car is giving me warning messages like ABA, Transmission fails safe with only 5 and 6 speeds, the car has lost all power for a minute and then rebooted itself, While driving on the highway it has caused a hard bump in the tranny, warning lights after as above etc. We downloaded the transmission module software and it has helped a little the downshifting but the other issues no, one dealer says it is the mechatronics in the transmission which is around $3400 another says new tranny needed, another says there are some pins in the rear which need checking, Any body got an idea?
Mark
Aug 30, 2009 at 11:39 AM
MFSUTN
I found the problem. After the BMW tech said it was a Megatronics, $4000 part in the transmission, I found the reason for the many faults and electrical errors the car was displaying. It was a loose battery cable causing these problems everytime I hit a bump. Thanks BMW techs for your advice.
Sep 14, 2009 at 9:48 AM
