Parking brake malfunction
CIAOMUFF
V8 two wheel drive automatic 60,000 miles.
I have the yellow warning sign on the dashboard that the parking brake is malfunctioning.
No other problems exist with the car, electrical, warning icons, etc.
Is this a matter of tightening the parking brake cable, or possibly rear brake pads need replacement?
[img:f77507d195]http://www.2carpros.com/forum/automotive_pictures/415942_BMW_int_3_1.jpg[/img:f77507d195]
Sep 30, 2009 at 11:12 AM
MATHIASO
  • 1,209 POSTS
The parking brake shoes are adjusted through one of the wheel bolt holes-E36 models shown, E30 similar. The parking brake may be tight.or there is a binding on the parking brake system.
https://images.2carpros.com/forum/automotive_pictures/46384_parking_brakesgif1_1.jpg
The star wheel adjuster is moved by pivoting the adjustment tool-E36 models shown, E30 similar
https://images.2carpros.com/forum/automotive_pictures/46384_parking_brakes_1.jpg
Sep 30, 2009 at 11:25 AM
CIAOMUFF
But I am not sure you understood my question. The "malfunctioning brake" light is illuminated, but there is no binding. Simply put, the parking brake will not engage when I press the electronic parking brake button. Is this due to worn parking brake pads? Or shall I try to adjust them? Could this be an electrical problem? A fuse burned out? I can check all, but thought maybe to ask first as this may be a common problem/function of this model. Thanks in advance.
https://images.2carpros.com/forum/automotive_pictures/415942_parkbrake_1.jpg
Sep 30, 2009 at 1:57 PM
DOCHAGERTY
  • 9,606 POSTS
The parking brake is electrically actuated and may need service, it will need to be checked by a BMW knowledgeable technician who can scan the car and deliver the diagnosis. It is not possible for me to pinpoint the issue from here. Do you have a repair facility that has been servicing the car?
Sep 30, 2009 at 2:16 PM
MATHIASO
  • 1,209 POSTS
That is correct Dr. Hagerty, a continually illuminated brake warning light may be cause by a grounded wire to the parking brake switch, or a continually closed parking brake switch, or low fluid level one section of the master cylinder reservoir.
follow what Dr. Hagerty, take it to a BMW facility. you have a nice car there.
Oct 1, 2009 at 9:45 AM
MSNIKA
I wanted to know how it was resolved. 2003 745Li
https://images.2carpros.com/forum/automotive_pictures/537617_bmw_light_1.jpg
The light is yellowish instead of red as it is when engaged.
Jun 10, 2010 at 3:35 PM
DOCHAGERTY
  • 9,606 POSTS
Me too!
Jun 11, 2010 at 1:10 AM
