2000 BMW 745 2000 bmw 745il
ZIP
Transmission problem
2000 BMW 745 V8 Two Wheel Drive Automatic
car goes into emergency transmission mode. i can turn car off and restart and it is good for a couple of days. i had it repaired before and they replaced the traction control sensor. is this something i can do myself
Dec 29, 2008 at 11:42 AM
DOCHAGERTY
  • 9,606 POSTS
This may not be something you can do if the repairs require coding or programming. Is this a 740il or a 745?
Dec 29, 2008 at 1:56 PM
ZIP
sorry it is a 740il if it requires codeing i can not. if it is a plugin part i can, thanks
Dec 29, 2008 at 3:18 PM
HDOUGLASUS
Your transmission fluid need to be flushed and change
bmw recommends their fluid which can cost about $50.00 a qt. I had the same problem and I used the amsoil brand which cost about $10.00 a qt. trans has been working fine for 2 years.
May 26, 2009 at 12:41 PM
