2001 BMW 740 RT REAR WINDOW REGULATOR.
2001 BMW 740
120,000 MILES • V8 • 2WD • AUTOMATIC
ZBABAR
HELLO,
I HAVE 2001 740iL SERIES, WANT TO REPLACE RT REAR WINDOW MOTOR AND REGULATOR ,PLEASE HELP ME HOW SHOULD I REPLACE IT, WHAT KIND OF TOOLS I NEED, IS IT EASY TO REPLACE IT? IS THERE ANY RIVETS THAT NEEDS TO BE DRILLED OUT? AND HOW SHOULD U PULL DOOR PANEL? IS THERE ANY HIDDEN SCREWS?
THANKS
Dec 22, 2008 at 9:53 AM
DOCHAGERTY
  • 9,606 POSTS
Is there a quarter glass and side window shade? Do you have any car repairing skills and do you have the tools? It will not require special tools, just a metric socket set, 1/4" drive, screwdrivers, plastic prying tools, Torx drivers, time and patience. And the replacement window regulator, the motor may be still okay to use.
Dec 24, 2008 at 2:53 AM
ZBABAR
yes there is a sliding window shade and quarter glass this 740iL has it, I am also ASE certified and worked mostly on Japnese cars, like Lexus,toyota and honda,I never worked on BMWand MBenze cars.
Dec 24, 2008 at 6:00 AM
DOCHAGERTY
  • 9,606 POSTS
Great, you can fix this no sweat. Do you have the regulator yet? I will repost the instructions after we (Me and the Wife) get back tonite from Xmas celebrations.
Dec 24, 2008 at 11:44 AM
ZBABAR
thanks,
I did not have Regulator yet.
Please instruct me through the process, just pin point.
thanks,
looking forward your response.
Dec 29, 2008 at 2:20 AM
DOCHAGERTY
  • 9,606 POSTS
I will be back with your answer tonite, sorry about the delay.
Dec 29, 2008 at 4:04 AM
ZBABAR
that is okey , take your time.
thanks again
Dec 29, 2008 at 4:59 AM
