2000 BMW 740 odometer and speedometer dont work
120,000 MILES • V8 • 2WD • AUTOMATIC
WILLMCCONNELL63
cant get speedometer and odometer to work!!!!!!!
Jun 4, 2010 at 12:28 AM
DOCHAGERTY
  • 9,606 POSTS
The DSC control module may have failed. It sends the road speed signal to the instrument cluster.
Jun 4, 2010 at 2:14 AM
GRADY_TX
  • 6 POSTS
Mine is older (1995) but I had a bad left rear ABS sensor that killed the speedo, odo, cruise, windshield wipers - everything that had a "speed" input plus the airbag light came one. A new sensor fixed all of it.
IIRC - The newer models take readings off both rear wheels. And maybe the front wheels too. Google it.
Before diving under the dash, figure out what is controlled by which wheel. Try swapping or replacing one. (A 5mm hex and a few minutes work.) Grady
Jun 24, 2010 at 4:57 PM
DR LOOT
  • 2,311 POSTS
thanks for the tip
Jul 20, 2010 at 5:13 PM
