1999 BMW 740 trans doesnt shift
159,000 MILES • V8 • 2WD • AUTOMATIC
AMIR DAWUD
trans fail safe comes on and fault code 015 stored in trans module, clear the fault and start the car up and the fault comes oin again
Sep 21, 2010 at 11:25 AM
DOCHAGERTY
  • 9,606 POSTS
A more comprehensive diagnosis would seem to be in order. A scan of the cars' systems with the proprietary BMW software is next. Do that and get back to me.
Sep 22, 2010 at 3:36 AM
DR LOOT
  • 2,311 POSTS
sorry for the intrusion I just have one question,
1. Is your transmission leaking oil?
you can only check the transmission oil on this particular vehicle on a rack, with the vehicle at operating temperature and running, and it requires a special tool to remove the plug, if the transmission is low on fluid it will start to malfunction and set codes, I suggest you have your transmission fluid level checked, remember BMW requires its own special transmission oil available at a European parts store, Or the dealer, don't worry it is only $34 a pt.
Sep 27, 2010 at 4:31 PM
