1997 740il Transmision trouble zf5hp30
1997 BMW 740
DGRIZZZ
  • 7 POSTS
I have a v8 with a zf5hp30 trans. This is a two owner car me being the second It has 183000 miles. I have had is since 90000miles. It has been mantained at bmw shop. Just recently I was getting a clunk on downshift. I took it in to be serviced and check the clunk. They checked codes and it showed voltage fault and brake level sensor. They said they stress tested the tranny and said it needed to be replaced. So I had my wife pick it up. She barely got home on limp mode. I was out of town at the time. I got home and pulled the batt to find it was bad. I changed the batt and now I am getting 2 different codes. P0720 & P0733 It will not hold a forward gear it goes to slipping or neutral. If I putt it in reverse it will go good. I put it in drive and it hits good then goes back to neutral. I am not sure if the trans is bad now or just the output speed sensor. Any Ideas?
Oct 4, 2007 at 4:36 PM
DOCHAGERTY
  • 9,606 POSTS
inspect the fluid.
if it is burnt, replace the transmission.
at that mileage the trans is probably toast.
Oct 5, 2007 at 2:39 PM
DGRIZZZ
  • 7 POSTS
I have now re-built the transmission but did not replace the speed sensors. I am still getting the code P0720-(Output speed sensor Cuircut malfunction) now that everthing is back together. when I went to test drive the car, there were no codes detected. on return i checked again and I am now getting the P0720 code. What do you suggest?
Oct 21, 2007 at 4:08 PM
DOCHAGERTY
  • 9,606 POSTS
Oct 28, 2007 at 4:30 PM
DGRIZZZ
  • 7 POSTS
Ok I have replaced the speed sensors and resolved all problems. The trans road test great!! The funny thing is that now I have got a o2 sensor code. P0150 wich is o2 sensor bank two sensor one. But out of the 4 that are there wich is it and how come it decided to go bad al of a sudden?
Oct 28, 2007 at 11:58 PM
DOCHAGERTY
  • 9,606 POSTS
they do that, replace the sensor with an OE BOSCH UNIT ONLY!!!!!!!!!!!
then reset adaptations and drive the car.
have a nice day
Oct 29, 2007 at 3:59 AM
DGRIZZZ
  • 7 POSTS
One more thing if you dont mind. The sensor that is bad can you tell me which position it is? THere are 4 so is it the right side first one back or the left side second one back? code is p0150
Oct 29, 2007 at 1:05 PM
DOCHAGERTY
  • 9,606 POSTS
bank one is right side and it will be before the cat
Oct 29, 2007 at 1:34 PM
DGRIZZZ
  • 7 POSTS
Thank You, I will change it out next weekend!!! Duane
Oct 29, 2007 at 1:48 PM
DOCHAGERTY
  • 9,606 POSTS
have a good day
Oct 29, 2007 at 3:45 PM
