1999 BMW 740 P1420 secondary air circute electrical
SCAR09FACE
MEMBER
1999 BMW 740
V8
2WD
AUTOMATIC
140,000 MILES
Does any body know what I need to do to fix this code? Please help!
Sunday, December 28th, 2008 AT 3:08 PM
2CARPRO JACK
MECHANIC
Please be patient, I have sent your link to our resident BMW doctor.
SPONSORED LINKS
Tuesday, December 30th, 2008 AT 9:14 AM
DOCHAGERTY
MECHANIC
If the fault was set for secondary air then there is a possibility that there is some restriction/occlusion built up inside the air injection ports and the carbon build-up will need to be removed, or the secondary air pump/secondary air injection valve is not working correctly. How were the fault codes extracted, what device was used?
Tuesday, December 30th, 2008 AT 12:53 PM
SCAR09FACE
MEMBER
I've used two difrent devises one from o'raileys and the other one from my friends shop and they both came up with the same code p1420 I would realy apretiate if u could give me a call if u can I can tell u a little bit better on whats been going on with the car my number is 979-627-3494
