1999 BMW 740 P0500 Code
129,680 MILES • V8 • 4WD • AUTOMATIC
CHRIS LITTLEJOHN
Speedometer not working and ABS,Traction control & brake light on
Jun 5, 2009 at 7:03 AM
DOCHAGERTY
  • 9,606 POSTS
This might require replacement of the ASC/DSC control module. Often its' failure will include setting wheel sensor failure faults, when the wheel speed sensor is working just fine. The road speed signal is generated from the ASC/DSC module and then sent via bus communications to the instrument cluster.
Jun 5, 2009 at 9:12 AM
