1999 BMW 740 OIL IN SPARK PLUG WELLS
121,000 MILES • V8 • 2WD • AUTOMATIC
740KSLAV
WILL REPLACING THE SPARK PLUGS HELP STOP PLUG WELLS FROM FILLING WITH OIL?
Feb 8, 2009 at 10:02 AM
  • 75,988 POSTS
You need to check if the valve cover gasket is leaking.
Feb 8, 2009 at 10:51 AM
DOCHAGERTY
  • 9,606 POSTS
Ras is on the right track. You have valve cover gaskets leaking into the spark plug wells and they will require replacement and there might also be a need for other work such as a valley pan replacement, the PCV plate and the throttle plate profile gasket.
Feb 8, 2009 at 1:40 PM
