1999 BMW 740 antifreeze leak
JAESMOOVE007
Engine Cooling problem
1999 BMW 740 V8 Automatic 96240 miles
my antifreeze is constantly leaking out and its not the holes nor is it the antifreeze container one mechanic told me that it is the fan clutch because it spends verysluggish and that he can stop the fan with his hand is this true??
Mar 15, 2008 at 2:19 AM
DOCHAGERTY
  • 9,606 POSTS
Did he say the fan clutch was leaking coolant? The coolant leak might be from the valley pan. BTW there is no coolant in the fan clutch, maybe he meant the fluid inside the clutch all leaked out and the fan clutch does not work anymore and was at the cause of this issue.
Mar 16, 2008 at 5:34 AM
