1998 BMW 740I ---Vent Problems
PKEYZ
1998 BMW 740I
Hot air is blowing out of the floor vents & cold air is blowing out of the upper vents & there is a strange coolant odor when the defroster is in use.
Apr 8, 2009 at 3:42 AM
DOCHAGERTY
  • 9,606 POSTS
The IHKA system needs to be scanned for faultsand the cooling system should be pressure tested to pinpoint the source of the leak. If you can smell the coolant, its leaking and you should have it checked straight away mate.
Apr 9, 2009 at 4:39 AM
