1998 BMW 740 temp gage pegs cold
76,000 MILES • V8 • 2WD • AUTOMATIC
PURINEAUTO
master tech 1990-2015 3 days in. I have no power to sending unit. evaporator drain hose was kinked and filled floor with water. power dist. box was badly corroded as well as splices directly in front of it . several wires were corroded and broken I cut wires and installed eyelets to dist. box and tested all wires with logic probe this fixed power to obd port . temp gage will work int. no change there. all data no help. car was just purchased and I have no history on it. where should I go from here?
Sep 10, 2010 at 7:35 AM
DOCHAGERTY
  • 9,606 POSTS
Inside the electrical distribution box is a 5 fuse block, check all for continuity.
Sep 10, 2010 at 8:34 PM
PURINEAUTO
I replaced all of the wire ends with eyelets and bolted them down. all of the wires have power coming out of the power dist. box. I also checked and repaired the splices directly in front of the box. the guage does work intermittently. where does the power go from there? computer? module in pass kick panel? the guage? where to next? If only alldata had a wiring diagram! thank you for your help! at least now I have a starting point.
Sep 11, 2010 at 9:41 AM
DR LOOT
  • 2,311 POSTS
Check this out...http://www.wedophones.com/BMWManualsLead.htm
Sep 27, 2010 at 4:44 PM
