master tech 1990-2015 3 days in. I have no power to sending unit. evaporator drain hose was kinked and filled floor with water. power dist. box was badly corroded as well as splices directly in front of it . several wires were corroded and broken I cut wires and installed eyelets to dist. box and tested all wires with logic probe this fixed power to obd port . temp gage will work int. no change there. all data no help. car was just purchased and I have no history on it. where should I go from here?
Sep 10, 2010 at 7:35 AM
