1998 BMW 740 hessitation
138,000 MILES • V8 • 2WD • AUTOMATIC
MMURCH1975
i take off from a lite and the car barely wants to go when i step on it then it starts to feel like it wont go int the next gear and when i stop it shakes like crazy i tuned the car up and changed the mass airflow still have the problem
Feb 15, 2010 at 11:22 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 15, 2010 at 12:41 PM
