1998 BMW 740 engine vibration
285,000 MILES • V8 • 2WD • AUTOMATIC
JT1966
I have a 1998 BMW 740iL with hijgh mileage. The idle is bad causing car to vibrate an it has a rich exhaust smell. Compression test reveals that all cylinders but one( number five is reading 150. But number 5 is reading 75. If this helps, the service engine light stays on constantly in yeloow and the asc/dsc light and abs light is on all the time.
Already replaced spark plugs.
Jun 1, 2010 at 11:56 PM
  • 31,937 POSTS
Hi there,
The low compression is a big concern, i would first get a wet comp test done as this swill help determine weather it is rings or calves at fault, also a scan to read the unresolved fault codes.
mark (mhpautos)
Jun 2, 2010 at 12:09 AM
JT1966
[quote:2dcec1dd25="mhpautos"]Hi there,
mark (mhpautos)[/quote:2dcec1dd25]Thanks for the quick response and help. Should I be considering an engine rebuild. or for that matter an engine?
Jun 2, 2010 at 1:18 AM
  • 31,937 POSTS
Hi there, i feel that at the mileage you have a top end o/haul will be fraught with danger as this will load up the lower end, i would be considering a full o/haul or a re-co long engine, but a wet comp test will tell us a lot and i would also get the valve clearance checked as a tight valve can cause this as well, best to know exactly what we are looking at first.
mark
Jun 2, 2010 at 1:29 AM
