1998 BMW 740 Engine Burns Oil
1998 BMW 740
14,000 MILES • V8 • 2WD • AUTOMATIC
BEN726966
I have a BMW 740IL that burns oil like mad. It puts a hug black smoke screen out bthe exhaust. I did a compression test and it was good. I unplugged vacum lines and found on twards the back of the motor that when unplugged the problem seemed to of went away. There is no PCV valve listed on the under hood emissions sticker. What would possibly be the cause?
Sep 12, 2009 at 2:19 PM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
The plate bolted to the rear of the intake manifold is the PCV valve. It may require replacement. 11-61-7-501-563 is the part number and it can be viewed at Realoem.com
Sep 13, 2009 at 8:16 AM
HEIFETZ17
  • 10 POSTS
The reason this part is so obscure is because it's not a PCV valve, but functions the same as one. BMW doesn't use PCV valves, but instead these components. That rear plate is an oil separator valve.
You have an oil separator in the front of the engine that separates oil and excess unburned gasses. It sends the oil to the oil pan and the gasses back through the intake to be burned off. It's not quite the same as a conventional PCV valve.
When this OSV goes out, you'll get smoke at startup but not usually while driving, as the valve inside closes off when the intake vacuum increases, thus blocking any flow of excess oil. This is why you'll usually only smoke at startup.
Dec 24, 2009 at 1:15 AM
