1997 BMW 740 trani service
191,365 MILES • V8 • 2WD • AUTOMATIC
LINWOOD
how do fill the trani and how much to put in
Dec 29, 2007 at 11:34 AM
DOCHAGERTY
  • 9,606 POSTS
the filler plug is on the transmission main body casting, on the left side towards the rear. It will probably be an 8MM Allen head or maybe 17mm hex. The fluid is special and may be purchased at the local dealer. Do not use regular ATF or you will ruin the transmission. to fill remove the plug and with the engine running, fill till it runs out the hole. please donate if this is what you needed
Jan 2, 2008 at 2:28 AM
