1997 BMW 740 IDLE CONTROL
11,110 MILES • V8 • 4WD • AUTOMATIC
OMINA
I have replace the idle control valve yet is still show P0505 i have done every thing i can think off. Please advise
Mar 26, 2009 at 6:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check resistance of the connector to the Idle Speed Control Valve. Some models use a 2-pin connector while others use a 3-pin connector. Below is a reference chart for what the resistance should be wether you have the 2 or 3-pin connector..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_367.jpg
Thanks for using 2CarPros.com!
Mar 26, 2009 at 6:29 PM
OMINA
I don't know what to look for or what to do i change everythink yet the idle is still high and code p0505 is on. I have check everywhere for leakage in the hose. Please advise
Mar 30, 2009 at 11:35 AM
OMINA
You said i should Check resistance of the connector to the Idle Speed Control Valve. what did n need to change it with.
Apr 1, 2009 at 10:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
was the resistance incorrect?
Apr 2, 2009 at 6:44 AM
