1997 BMW 740 changing spark plugs
NEWLIFEET
Engine Performance problem
1997 BMW 740 V8 Two Wheel Drive 195000 miles
Hi, can you tell me the process to change spark plugs in a 1997 BMW 740i? I can't see where they are because a covering is hiding the plugs. What tool will I need to remove that covering? Thank you.
Larry
Aug 18, 2009 at 3:46 AM
DOCHAGERTY
  • 9,606 POSTS
I have a cat named Larry! The top of the covers have two square plastic covers, pop those out and relase the screws and off it comes! I use a pick tool, but a small screwdriver will do just fine, then remove the coils and the plugs.
Aug 18, 2009 at 11:45 AM
