1996 BMW 740 anti freeze smell when heater is on
1996 BMW 740
15,700 MILES • V8 • 2WD • AUTOMATIC
MARKOF.SPER
only when I use the defrost, i smell anti-freeze coming out of the vents, the car has a new water pump and thermostat, hoses, and belts. No leaks of any kind detected. thank you
Nov 11, 2008 at 7:45 AM
  • 31,937 POSTS
Hi there,
I would have the cooling system pressure tested hot with the heater on, as i feel that with the smell of coolant in the cabin, you may well have a small leak in the heater core, best to check this out.
Mark (mhpautos)
Nov 11, 2008 at 9:17 AM
