1995 BMW 740 Intermittent A/C
118,000 MILES • V8 • 2WD • AUTOMATIC
GRADY_TX
  • 6 POSTS
The subject is not quite accurate. The A/C works fine. What is intermittent is the blower.
It makes no bad noises, it always works in the morning or after a good rest; it just sometimes doesn't work on a re-start.
Mostly it will not work until the car sits for an hour or two. Occasionally it comes on after a 10-15 minutes of driving.
Turning the a/c switch and other controls on-off has no effect.
When off, a small amount of cold air still seeps through. The compressor clutch cycles on and off about every 30 seconds.
Yet I think it's a s sensor or switch rather than the entire blower (fingers crossed). Grady
Jun 24, 2010 at 1:32 PM
DOCHAGERTY
  • 9,606 POSTS
The final stage unit sits on top of the fan, and it is suspect.
Jun 24, 2010 at 5:10 PM
GRADY_TX
  • 6 POSTS
My book doesn't show a "final stage". It does refer to a power unit (which iItake to be the blower motor) are they the same or am I missing something?
Either way I assume access it via removing the air bag, dash, etc. Not sure I have the courage for that! What is the shop time to make the change?
Thanks Grady
Jun 25, 2010 at 1:30 AM
GRADY_TX
  • 6 POSTS
Nothing in the Bentley Book but lots of info on the internet. Appears to be a small electronic unit in the pass. foot-well and a easy change out.
I'll give a try thanks! Grady
Jun 25, 2010 at 2:04 AM
DOCHAGERTY
  • 9,606 POSTS
Did the problem get taken care of Grady?
Jul 7, 2010 at 4:31 PM
GRADY_TX
  • 6 POSTS
Not really - Turns out the easy-to-change version is only for 3 & 5 series, on a '95 7 series it's buried in the blower motor so it's a full-dash apart job to replace it.
The good news is that with a can of refrigerant, the a/c is cold enough to keep the module from overheating (I'm guessing).
Knock on wood, it has been working.
Thanks for checking. Grady
Jul 14, 2010 at 1:07 PM
DOCHAGERTY
  • 9,606 POSTS
Kool baby
Jul 15, 2010 at 2:25 AM
