1995 BMW 740 engine
JLOBAINA
  • 18 POSTS
Electrical problem
1995 BMW 740 V8 Four Wheel Drive Automatic
mi bmw 1995 e38 740il le puce el tiempo por lo que me dieron ustedes y lo prendi pero,muy atrasado y con muchas esplociones, yo se que hay algo mal,y pienso que deve ser el piston #1. me puede decir,el piston deve estar completamente arriba, o deve bajarce a la mitad, gracias
sorry! here is translation
I followed the instruction i recieved from you and managed to put timing chain on the car turns on but it seems late and it fires, i think it could be the #1 piston,should it go all the way up or half way or icould it be something else?
Oct 12, 2010 at 1:03 AM
DR LOOT
  • 2,311 POSTS
piston number one should be all the way to the top
Oct 14, 2010 at 3:57 PM
