How do you remove the pads on the front of a 1995 BMW 740i.
Jul 31, 2009 at 9:24 PM
DOCHAGERTY
✓Experienced Mechanic
Remove the wheel/tire and pop the dust caps caps off the caliper pins and push the piston back a bit then you can get the caliper off after you pull the pins and remove the anti-rattle spring.
