1996 BMW 735 steering
BMW735I
Steering problem
1996 BMW 735 6 cyl Two Wheel Drive Automatic 80 000 miles
sometimes when i drive my car my steering wheel goes hard, then after a while its soft again, is my power steering broken? thanks
Jun 12, 2009 at 10:53 PM
DOCHAGERTY
  • 9,606 POSTS
The power steering on the car uses what BMW calls Servotronic. It is speed controlled and it varies the amount of power assist available to the driver, more for parking lot maneuvering and less for the freeway. The system can have several types of faults, from module failure to low fluid level. To respond to this issue, you may need to seek out a skilled BMW tech as it may require some diagnostics to fully uncover the issue and resolve it. Do you feel qualified to approach this issue?
Jun 13, 2009 at 12:13 AM
