1992 BMW 735 won't start after it sits for an hour
1992 BMW 735
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANNIES735
I have to turn it over 8+ times to get it to start after it sits for more than an hour after running. Usually starts right up in the morning and within 15 minutes after turning off. But if it sits for more than an hour it acts like it doesn't get fuel. Replaced fuel pump and fuel pressure regulator. Could it be a relay?? Any ideas would be appreciated. - Annie :)
Jan 31, 2010 at 4:26 PM
DOCHAGERTY
  • 9,606 POSTS
Long crank times with that motor can indicate a faulty or loose crankshaft sensor. I have also seen the DME cause this issue. DME is the engine control module.
Feb 1, 2010 at 3:16 AM
