1991 BMW 735 GEAR SHIFT NOT HAPENNING
1991 BMW 735
324,444 MILES • 6 CYL • 2WD • AUTOMATIC
KAMAL CALCHAND
Sir,
The car is equipped with an auto gear box with E M S options for driving, on E position by default, the gear stays on first gear only, for the time being I have to drive it on M only at D position for the gear lever. Kindly help me diagnose the problem... is it with the solenoid valves, if yes can they be repaired.
Regards
Kamal
May 18, 2010 at 10:24 AM
DOCHAGERTY
  • 9,606 POSTS
A stuck piston or broken spring in the shift body of the transmission is possibly the issue here.
May 18, 2010 at 8:43 PM
