1986 BMW 735 ignition switch
214,667 MILES • 6 CYL • 2WD • AUTOMATIC
BOA7078
how do you remove ignition switch on a bmw 735i
Aug 16, 2010 at 2:48 AM
  • 75,988 POSTS
Steering Lock/Ignition Switch, Removing and Installing : *Disconnect minus lead at battery. *Remove and install trim lower section. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair
https://images.2carpros.com/forum/automotive_pictures/12900_i1_3.jpg
*Unscrew stud screw and pull out ignition switch. Installation Note !
https://images.2carpros.com/forum/automotive_pictures/12900_i2_3.jpg
*Turn back ignition key all the way. *Position ignition switch at 0. *Note mark and install ignition switch in this position.
https://images.2carpros.com/forum/automotive_pictures/12900_i3_2.jpg
*Loosen wire straps. *Disconnect single plug. *Pull off central plug and remove ignition switch. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 16, 2010 at 2:53 PM
