1986 BMW 735 ignition
214,667 MILES • 6 CYL • 2WD • AUTOMATIC
BOA7078
how to remove ignition
Aug 16, 2010 at 7:40 AM
DR LOOT
  • 2,311 POSTS
IGNITION SWITCH Removal & Installation Disconnect negative battery cable. Remove lower left dashboard trim. Remove screws and steering column lower trim. Press in retaining hooks on both sides of switch, and pull out ignition switch. To install, reverse removal procedure. Check ignition switch-to-steering wheel lock position.
Sep 26, 2010 at 6:12 AM
