1987 BMW 635 transmission shifts on revers and park only
1987 BMW 635
193 MILES • 6 CYL • 2WD • AUTOMATIC
MOEJAM
hi there, im trying to find the problem with my transmission, it was driving normal i parked the car on my driveway for five minutes came back put the car on drive..not moving, i try to put it on 3..2 ..1 the car not moving feels like it's on nutral only the revers gear response and when i put it on park.....could it be the shifter cable or something else....thank you
Dec 21, 2008 at 9:05 AM
DOCHAGERTY
  • 9,606 POSTS
Start with checking the transmission fluid level, check it with the engine running.
Dec 22, 2008 at 7:51 AM
MOEJAM
hi there, i checked the transmission oil with the car running it looks fine, i also cheked the shifter cable linkage from the bottom of the car all the way to shifter handle...still i can't get the gear into drive . could it be the transmission computer or the diffrential......thank you and happy holidays
Dec 24, 2008 at 7:20 AM
DOCHAGERTY
  • 9,606 POSTS
It could be a bad "A" pack in the transmission, it could be a hundred other things as well. It is a practical impossibility to say from cyberspace what it is for sure.
Dec 24, 2008 at 11:40 AM
