2004 BMW 540i vibration on highway
59,000 MILES • V8 • 2WD • MANUAL
PAULIEHCFR
I have a 2004 BMW 545 with a manual transmission. I have been experiencing a vibration when cruising at around 65 MPH. Anything above or below, it goes away. I had 4 new rims and tires installed and roadforce balanced. The rims/tires checked out fine. I thought maybe the parking brake drum was warped because someone previously installed the returne springs wrong and the parking brake didn't release correctly. The vibration was still there after I removed the parking brake shoes though. The vibration comes through the seats and is speed dependant only. If I downshift to a lower gear like 4th or 5th, it is still noticeable. I was wondering if maybe the rear rotors could be warped enough that they are casuing the vibration however, I get no vibration when I apply the brakes.
Sep 23, 2009 at 8:35 AM
DOCHAGERTY
  • 9,606 POSTS
Have you inspected the driveshaft?
Oct 7, 2009 at 3:11 PM
